Drivers for Vu+Duo & solo
This is a sticky topic.
  • Drivers for Vu+Duo & solo
    Drivers for Vu Solo
    25.04.2011
    - Fix LPCM Sound problem in vob and media playback
    - Fix EOS detection problem in media playback
    - Fix some CI modules recognition problem
    - Reduce booting time(Needs a image update)
    - Change SRC_URI of driver
    vuplus-dvb-modules-vusolo-2.6.18-7.3-4.4.3-20110425.tar.rar
    VU Duo Drivers
    vuplus-dvb-modules-bm750-2.6.18-7.3-4.4.3-20110425.tar.rar
    Home / VU DUO / Drivers
    - Fix timeshift problem
    now in upload there are only latest files
    • #3
      New Drivery VU+ Duo, Solo, Solo2 , Uno, Ultimo VTI image
      ipk rt3070_2.5.0.3-r2_vusolo.ipk ipk rt3070_2.5.0.3-r2_bm750.ipk ipk rt3070_2.5.0.3-r2_vusolo2.ipk [/CODE]
      ipk rt3070_2.5.0.3-r2_vuultimo.ipk ipk rt3070_2.5.0.3-r2_vuuno.ipk
      • #4
        VU+ SOLO2 New Drivers
        • #5
          Beta Driver VU+ Duo┬▓ Update: 03.05.2013
          update duo2 driver
          - Fix LCD/VFD brightness control
          - Fix Tuner Loop through
          >> Download <<
          • #6
            VU+Official Drivers Update: 09.05.2013
            Update driver
            20130509
            - Fix invalid module format(duo2)
            >> Download <<
            • #7
              Duo2 driver update 20130719(duo2)
              - Fix Play/Pause key problem
              - Support FP update
              - Support VFD controller update
              >> Download <<
              • #8
                VU+ Drivers 20130722(duo2)
                - Fix loop-through problem when 2 dual tuners are installed
                - Improve VFD controller update(VFD controller update will resolve remote control sensitivity issue)
                - New VFD controller image and Upgrade HowTo document are at Archive of Vu+
                - To upgrade VFD controller image, "Firmware Upgrade" plugin is needed.
                >> Download <<
                • #9
                  VU+ Duo, Solo, Uno, Ultimo, Solo2, Duo2, update drivers 20130731
                  - Fix AGC in dual tuner & Solo2 internal tuner.
                  - Fix RTC problem when awake from front power button(solo2)
                  - Fix high bit rate problem(solo2, duo, solo)
                  - Fix SPDIF no sound prlblem(duo2)
                  - Fix RTC problem in WOL standby(duo2)
                  gz vuplus-dvb-modules-bm750-3.1.1-4.4.3-20130731.tar.gz (2.09 MB, 2 >> Download <<
                  gz vuplus-dvb-modules-vuduo2-3.3.8-4.4.3-20130731.tar.gz (4.00 MB, 2 >> Download <<
                  : gz vuplus-dvb-modules-vusolo2-3.3.8-4.4.3-20130731.tar.gz (3.36 MB, 1 >> Download <<
                  gz vuplus-dvb-modules-vusolo-3.1.1-4.4.3-20130731.tar.gz (2.03 MB, 1 >> Download <<
                  : gz vuplus-dvb-modules-vuultimo-3.1.1-4.4.3-20130731.tar.gz (2.19 MB, 1 >> Download <<
                  gz vuplus-dvb-modules-vuuno-3.1.1-4.4.3-20130731.tar.gz (2.18 MB, 2 >> Download <<
                  • #10
                    VU+Drivers Update : 10/03/2014
                    Quote:
                    Update drivers
                    20140310
                    - Fix PCM MultiChannel problem(solo2, duo2)
                    - Fix vtuner PIP
                    - Fix Dual tuner loop-through input from single tuner(duo2, ultimo)
                    gz vuplus-dvb-modules-bm750-3.1.1-4.4.3-20140310.tar.gz (2.29 MB, Download gz vuplus-dvb-modules-vuduo2-3.3.8-4.4.3-20140310.tar.gz (4.09 MB Download
                    gz vuplus-dvb-modules-vusolo2-3.3.8-4.4.3-20140310.tar.gz (3.58 MB, Download
                    gz vuplus-dvb-modules-vusolo-3.1.1-4.4.3-20140310.tar.gz (2.22 MB, Download
                    gz vuplus-dvb-modules-vuultimo-3.1.1-4.4.3-20140310.tar.gz (2.49 MB, Download
                    gz vuplus-dvb-modules-vuuno-3.1.1-4.4.3-20140310.tar.gz (2.48 MB, Download
                    • #11
                      VU+update driver
                      20140424
                      - Fix multichannel audio problem(solo2, duo2)
                      gz vuplus-dvb-modules-vuduo2-3.3.8-4.4.3-20140424.tar.gz (4.09 MB, Download
                      gz vuplus-dvb-modules-vusolo2-3.3.8-4.4.3-20140424.tar.gz (3.58 MB, Download
                      • #12
                        update drivers 06-04-2015
                        update drivers
                        20150406(duo, solo, uno, ultimo)
                        - Support satip(OE update will follow. Other models are already supported)
                        ultimo
                        uno
                        duo
                        solo
