enigma2-plugin-extensions-chocholousek-picons_4.0.210429
  • enigma2-plugin-extensions-chocholousek-picons_4.0.210429
    4.0.210429
    Fixed typo: "XPpicons" to "XPicons"
    File Type: rar enigma2-plugin-extensions-chocholousek-picons_4.0.210429_all.ipk.rar (94.2 KB, https://uploadfile.pl/pokaz/2152192---z87p.html
    File Type: rar enigma2-plugin-extensions-chocholousek-picons_4.0.210429_all.deb.rar (94.2 KB, https://uploadfile.pl/pokaz/2152193---kso1.html
    Update Plugin Chocholousek Picons!
    chocholousek-picons_5-0-210501
    Added multiple configuration profiles:
    - since there has also been a change in the system file "/etc/enigma2/settings",
      it is recommended to delete "chocholousekpicons" old configuration entries, for example using an online script:
         wget -qO- --no-check-certificate "https://github.com/s3n0/e2plugins/raw/master/ChocholousekPicons/online-setup" | bash -s del-config
    The ability to check and save the plugin configuration is removed:
    - the plugin configuration is SAVED AUTOMATICALLY and immediately after each change
    - the red "Exit" button has been replaced by "Profile reset" for this purpose
    - the green button is used to exit the plugin
    New option to add default picon directories, for Enigma2 administrators and developers:
    - create a text file "/etc/enigma2/chocholousekpicons.cfg" (Unix/Linux newlines)
    - insert the configuration section [picon_dir] into the file and insert the required directories to the picons below it (one line = one directory)
    - note: this file will also be used instead of the original file "/etc/enigma2/3rd_party_picons.ini",
      which was intended for downloading external archives 7z with picons (for example SRN picons) - only under configuration profile number 1 !!!,
      just add a configuration section named [picon_url]
    - comments are allowed with a "#" sign at the beginning of the line
    - example file content:
    # /etc/enigma2/chocholousekpicons.cfg
    [picon_dir]
    ### picon directories - for PurE2 needs:
    /media/ppmedia/picon
    /media/ppmedia/picon_50x30
    /data/picon_100x60
    ### picon directories - for Ellano.sk needs:
    /usr/share/enigma2/hdg17_files/picon
    #[picon_url]
    #http://download.test.net/files/my_picons.7z
    #http://example.com/files/iptv-special-picons.7z
    enigma2-plugin-extensions-chocholousek-picons_5.0.210501_all.ipk https://picon.cz/plugin/#down
    enigma2-plugin-extensions-chocholousek-picons_5.0.210501_all.deb https://picon.cz/plugin/#down
