CUBEREVO IPBOX mod PKT "Gold" - flash
Mod Pts svn 457 - "Gold", is based on the image Tideglo 1.0.0 rev. The main changes since the last version of Flash
- New EmuManager 1.0.2 - add support vizacam and ****
- Optimization and acceleration of InfoCenterPKT
- Added SkinSetup
- Added plugin POINT Channel Controle - including Set individual volume controls for each channel
- Added plugin KeyMapper - can personalize the color keys, support for long / short press
- Fix DVD Player - DVD watching is no longer threatens to boot
- Fixes and cosmetic skin (eg infobar dimmer, display the HDD temperature infobar - default OFF)
- Added skin GoldHD
- Added plugin ScreenSaver
- Automatic mapping Picon, if there is a folder / hdd / Picons
- Fix detection satellite name for item 9E when the list of satellites is also the position 39E
- Added ability to edit the recording options menu Paths HDD
- Update Picon
- Updated list of channels
- Amendments EmuCamInfo
- The permanent inclusion of the time 24 / VFD - because it was different from
- Fixed output from TeleText'u (Teletext)
- Other fixes performance and code optimization
[KeyMapper - comments]
Red -> Default, Media Player, Media Center, Permanent Clock, Channel Control, Disabled
Green -> Aspect Ratio, Screen Saver, Channel Control, Disabled
Yellow -> Plugin Browser, Emu Manager, Skin Setup, Disabled
Blue -> Blue Pane, Emu Manager, Skin Setup, Disabled
Each key can be assigned a separate action for the shares short / long press.
[Controle Channel]
Setting the call in KeyMapper by pressing red or green - depending on your preference.
However, this version is pretty early, so not everything works including inability to set individual values ​​of Aspect Ratio for the channel.
for register user
http://e2.pkteam.pl/index.php?dir=IMAGE%20IPBOX%20CUBEREVO/Enigma2/1.0.0.457_flash_Gold/
__________________
