Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 151
Thread: DM800 Clone images:
  1. #41
    Join Date
    Jun 2007
    Posts
    272
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    10
    Default
    Quote Originally Posted by <<ELVIS>> View Post
    Modified Images for DM 800 clones
    Gemini 5.10 for clone DM800HD
    [Only Registered Users Can See Links. Click Here To Register]
      SIM2.01 Features:
      SS76A
      Genuine validation by
      Full use of original drive
      Gemini2 v5.1
      Enigma from 21.07.2010
      Function Buttons:
      * BLUE - Blue Panel (BP)
      * BLUE long - Picture in Picture (DM7025, DM8000)
      * 2x BLUE - BP -> Gemini Extras
      * BLUE RED - File-Manager
      * RED - Recording (not for DM8000)
      * GREEN - Quickbutton / Subservices
      * YELLOW - Timeshift (not for DM8000)
      Extras:
      * Addon and Plugin Server
      * Cryptinfos of the channel or Cam, Stick Cam to certain channels
      * Function for managing many daemons / server (BP -> Services/Daemons)
      * optical enhancements like HD-skin, additional icons or modification of the channel list
      * Manager for format, setup or mount devices (BP -> Device-manager)
      * Additional EPG-functionality like Autosave, Refresh or different EPG-format view
      * Particular addons like Dreamnetcast, Jukebox, Calendar, eMail or eTorrent, just to name some of them
      * Quickbutton, to define functionality of the Green button via menun
      * Detailled information about your Dreambox (Menu -> Information)
       * File-Manager, which can handle different format-types, regardless whether it is a picture-, audio-, videoformat, playlists, torrent, scripts or DVD-files (BP -> File-Manager)
      * complete handling of hard disks, DVD-drives, USB-Sticks changed to udev (system handels those devices by itself)
      Information about many other functions can be found at the IhaD-Board or our Wiki.
      New:
      * HFS- and HFSPlus filesystems included
       * Info about new release. Atcivate over BP->Settings->General. Then will blink a "R" in the Infobar, if something new is out. The Check will be done between 00:00 and 01:00.
      * Partitions can be named anytime now.
      * The Filemanager can start everytime with the same selectable folder now.
      * OpenVPN now supported, in our wiki is already described, how to use the dream as server.
      * Webinterface for ctorrent
      Fixes + Updates:
      * better support for Unicable
      * Countries/Cities lists extended in the Weatherplugin
      * update to ctorrent 3.3.2, addon revised
      * see CVS
      Important:
      For the Skiners:
      A Change in the network-overview and in Skin_Config2Button (have a look at BKskin.py)
      This image doesn‘t contain any keys or softcams!
      Backups or other modified images are not released by us
      and won‘t be supported in any way!!!
    sim1-#69-gemini2-510-dm800-mfaraj.nfi (42.06 MB)
  2. #42
    Join Date
    Apr 2009
    Posts
    4,959
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    28
    Default
    Benfica Image- Hispasat Ready - Sat4fun Backup - 30-08-2011
    Based on Nemesis 2.3 SVN 091-dm800-22-08-2011-ramiMAHER #ssl82
    -Update Kernel for all Machine
    -Update dreambox-dvb-modules for all Machine (20110821) modified
    -Update v4l-dvb-modules for all Machine
    -Add check for original HW (by @gutemine)
    -Add more function on enigma2
    -Update crossepg to svn 306
    -Update enigma2 modified
    -Update enigma2-plugins
    EXTRAS
    TSpanel
    SIM 201 Flash backup
    CCcam Info v 1.3c
    VLC player mfarj57
    EDG Extra URL
    Hispasat Settings 21/08 /11
    Spinner fans
    media player mfaraj57
    Emus Installed
    CCcam 2.2.1
    MGcamD 1.3.5a
    http://www.speedyshare.com/files/30101709/Hispasat_Backup-dm800-2011-08-30-SSL-82.rar
  3. #43
    Join Date
    Apr 2009
    Posts
    4,959
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    28
    Default
    nemesis-2.3-svn91-DM800hd-sim2.1-by-power-sat
    thanks vyper and langioletto for the IMAGE..the Italian job
    Power-Sat boot-logo by aguda thanks to him..
    Nemesis Italian job at is best
    Plug-in installed Barry-Allen5.1.54-Dumbo-GSU-Light..to recognise you memory stick and Media USB tested and work
    Dflash backUp for all backup made easy tested and work
    Download Extra for all your EMU download tested and work
    4 EMU installed
    CCcam2.21
    CCcam2.13
    scam 260
    Dccam
    oscam Cardserver_r5560
    Last vhannibal setting
    the image work on Clone 100%
    Timeshift (Pause)
    Media Player
    WebInterface
    WiFi
    LCN
    work 100% with original files "no patched from old version"
    No need to send SS82 its included on the IMAGE.
    Version del 30/08/2011:
    this IMAGE been create direct from base SVN091 not from SVN085 "
    original Drivers from 21/08/2011 "removed control anti-clone"
    emigma2 del 06-07-2011
    time "been fix"
    fix the problem WiFi "my fix and bobsilvio"
    L'immagine contiene:
    Picon aggiornati per 13E "HotBird" e "DTT Italia"
    Un'altra Skin "Army Gradient" oltre a quella di default, la potete abilitare dal Menu > Configurazione > Sistema > Skin
    Funzioni aggiuntive per la gestione dell'epg direttamente dalla lista dei canali, raggiungibili tramite i tasti 1 - 2 - 3 - 4
    added:
    CDPlayer, for the reproduction of the CD
    DVDPlayer, for the reproduction of the DVD
    VLC Player (use search google: VLC dm800)
    dFlash, it is a software in order to create Backup you can found on address web from the DreamBox:
    In order to make a Backup obviously you need to installed a HardDisk.
    Change log 089/090/091:
    ===== Date: 22-08-2011, SVN 091 =====
    *********** PUBLIC RELEASE ****************
    Attention dm8000 users can perform update only if you have 078,
    if your version <078 need reflashing with 085
    Attention if your version is < 072 please refer SVN 072 section for upgrading info
    if your version is 072, 073 or 074 please refer SVN 075 section for upgrading info
    * Update Kernel for all Machine
    * Update dreambox-dvb-modules for all Machine (20110821)
    * Update v4l-dvb-modules for all Machine
    * Add check for original HW (by @gutemine)
    * Add more function on enigma2
    * Update crossepg to svn 306
    * Update enigma2
    * Update enigma2-plugins
    ===== Date: 08-08-2011, SVN 090 =====
    * Update Enigma2-Plugins (Fix mytube player)
    ===== Date: 28-07-2011, SVN 089 =====
    * Add initramfs kernel 1.0 "Non funziona sui cloni! kernel di boot" Io l'ho sostituito e adesso sui cloni funziona al 100%
    Thanks @adenin for the kernel
    Thanks @gutemine for the patch
    Thanks @bluebyte for this request
    * Update gst-plugins-bad
    * Update pcsc-lite to 1.7.4
    * Update ccid to 1.4.4
    * Small bug fix
    * Add crossEPG setup panel on EPG Control Center
    * Update Enigma2
    thanks langioletto to give the permission at power-sat
    thanks to voyger for testing
    Download link
    http://www.multiupload.com/8Y3VJ143M9
  4. #44
    Join Date
    Dec 2010
    Posts
    732
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    8
    Default
    Sat4fun-sim201 Dream elite Blackhole 133 ALL New
    For DM 800HD sim 201 (SSL 82)[/B]
    For clones DM800HD sim201 only
    installation in internal flash or in multiboot
    New patching solution
    Tested working functions:
    TSpanel
    video player
    time shift
    webinterface
    recording
    play back
    Softcam Feeds
    software and extension manager
    All Options work same as original Dream box
    secondstage loader 82
    Drivers 02.09.11
    Big Thanks to to sim 2 team
    Addon manager
    For more option go to Green then yellow
    CCCam 2.1.4 is active
    http://www.multiupload.com/G3FR4Q2O9D
  5. #45
    Join Date
    Apr 2009
    Posts
    4,959
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    28
    Default
    Nemesis2-3-dm800HD-SVN(092)-06-09-2011-ramiMAHER #ssl82
    Today, the protection of a different image
    But protect the new image is broken
    only sim201
    -Update Kernel for all machine
    -Update to InitramFS 1.4
    -Update dreambox-secondstage to 82 sim201
    -Fix some italian translation
    -Update enigma2
    Driver: 2011-02-09-ramiMAHER
    by ramiMAHER
    http://www.multiupload.com/WWLDY45YFZ
    or
    http://hotfile.com/dl/129161085/411cec2/Nemesis2-3-dm800-SVN%28092%29-ramiMAHER.rar.html
  6. #46
    Join Date
    Apr 2009
    Posts
    4,959
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    28
    Default
    Merlin-2-Excalibur-OE-1-6-dm800-20111016.Ssl.F82F.riyas66.nfi
    Update 16.10.2011
    Enigma2 Stand: 20110913
    Enigma2-Plugins: 20111017
    Enigma2-Skins: 20111017
    drivers 2-9-2011
    Second Stage Ferrari-sSL82F
    --Webinterface
    _Mediaplaye
    http://www.multiupload.com/JD4B3Y9B7Q
  7. #47
    Join Date
    Aug 2011
    Posts
    62
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    7
    Default
    DDD-dm800hd-1.2-OE1.6-ssl82-sim201
    new patching solution
    lien: [Only Registered Users Can See Links. Click Here To Register]
    Do not forget saving your settings from software manager before flashing any new image
    OK CLONE 800HD
    OK MULTIBOOT
    SOURCE: MULTI
  8. #48
    Join Date
    Apr 2009
    Posts
    4,959
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    28
    Default
    Ferrari-SSL82F-Nemesis2.3-dm800-e2-OE(1.6)-SVN(094)
     Webinterface
    - Mediaplayer
    - Timeshift
    - VLC
    - Wlan
    - CrossEPG
    - Mgcamd/NewCS
    - Extra.url
    - Ferrari AddOns Manager
    Timeline 094r3
    -Update gstreamer-plugins
    -Update to InitramFS 1.5 (thanks @gutemine)
    -Fix small bug on Blue Panel
    -Add minimum Image SVN version check, before upgrade
    -Add enable/disable upgrade Image info on Blue Panel
    -Add subrelease versioning
    -Add libbluray
    More languages
    Blue - Blue - Packet Management - enigma2-locale-xx
  9. #49
    Join Date
    Apr 2009
    Posts
    4,959
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    28
    Default
    OpenPLI2.1 Sim2-SSL84a-By sat4fun team
    Boodlogo Benkurd
    Second Stage Loader 84a
    Dreambox-drivers 02.09.11 Original
    Info
    Extras
    Skin army
    http://www.multiupload.com/Z3NI0C8F6V
  10. #50
    Join Date
    Apr 2009
    Posts
    4,959
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    28
    Default
    New sim2 ssl 84 for dm800(sim201 and sim210 cards)
    Sim2 released new sim2 second stage bootloader for dm800hd within the plan of continuous support for all sim products
    The new sim2 ssl 84 enables users to use original images with genuine drivers without modification on all types of sim2 dm800 boxes
    Also sim2 annouced that the new sim2 ssl 84 supports both sim2 card types for dm800hd(sim201 and sim201) and this proved all what said about stopping support for sim201 cards are totally wrong.
    Although the new ssl gives complete solution for sim2 dm800hd but there are some minor issues not resolved yet such webinterface ,wlan and software managers,however these issue could be fixed easily with available patches.
    also expected problems will be with few images like edg nemesis and oozoon images and in this case sim2 advice users to use already patched images.
    How to use new sim2 ssl 84
    -Flashing original images.
    1- load sim2 ssl84 to dreambox in setup mode by dreamup or internet explorer method then reboot the dreambox to setup mode again to activate the new ssl
    2- Flash the original image by dreamup or internet explorer methods
    3- without rebooting the dreambox flash again the sim2 ssl84 immediatley
    4-reboot the dreambox .
    -Flashing already patched images with sim2 ssl84
    just flash the image with dreamup or internet explorer method without loading sim2 ssl84 whatever the current ssl version loaded to dreambox
    -Updating already flashed image with sim2 ssl84
    we do not advice to update images in normal cases but for accidental updating we advice installation of new sim2 ssl 84.ipk before restrating the dreambox after finihsing update process
    for multiboot backup and osd flash image backup better to use sim2barryallen 4 and TSFlashbackup 4 which be available as soon as possible
    sim2 ssl 84 dm800hd should be used with the specified sim2 model,sim2 neither me are not responisble for any damage could occur from improper use.
    ot mfaraj57
    http://shrta.com/files/D9Q27G1Y/sim201_ssl84.rar
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
