Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 1 of 1
Thread: which settings for s/pdif?
  1. #1
    Join Date
    Dec 2009
    Posts
    1
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    0
    Lightbulb which settings for s/pdif?
    hi guys,
    i just installed the aaf christmas image after getting an ipbox 9000 hd. it seems to work pretty fine but the s/pdif does not work really. the amp works but there is no sound coming from the box.
    the setting was changed from pcm (or something like that?) to spdif and i did activate the default ac3 option.
    do i have to do anything else to get sound over s/pdif?
    other images didn't work either, tried some other new images from this site.
    problem "solved" -> amp does not work as it should
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
