Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
Thread: Help finding a damaged crystal 4.576000
  1. #1
    Join Date
    Apr 2008
    Location
    UK
    Posts
    117
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    12
    Default Help finding a damaged crystal 4.576000
    Ive damaged a component on the main board of my Abcom IPbox 9000 while replacing the fan. Basically the leg has come away from the body and cant be fixed.
    its a crystal and has engraved on it 4.576000 ( i take it that is Mhz )
    i was hoping someone can point me in the right direction where i can find 1 to replace it. I am sure the makers of the box are either from Germany or Holland
    Thanks
    Ive tried Maplins and they dont do that one. Also ive tried ebay.
  2. #2
    Join Date
    Apr 2008
    Location
    UK
    Posts
    117
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    12
    Default
    I phoned euroquartz and i need to confirm the right frequency as the one i posted in post 1 is not recognised. i am thinking it might be 24.576000 as opposed to 4.576000
    Can someone check in their ipbox to give me the right Frequency on the crystal, i can only make out what it says above in post 1, its possible part of it is missing.
    see where the arrow points to in the pic
  3. #3
    Join Date
    Jun 2009
    Posts
    13
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    0
    Default
    tried datasheetz ?
    i can't see the crystal on your picture, and i don't have an ipbox, but anyway could this be the one?`
    FXO-HC735-24.576MHZ
    Manufacturer: Fox Electronics
    Series: FXO-HC73, XPRESSO
    Short Description: OSCILLATOR 24.576 MHZ 3.3V SMD
    Lagavulin Slainthe
    DB 7000 -180 cm heated Dish, 18" actuator (1/3 bhp)
    DB800 HD - 90 cm Dish, single LNB
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
