Thanks Thanks:  14
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: ]NeoBoot by gutosie 6.41
  1. #11
    Join Date
    Aug 2010
    Posts
    17,180
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    78
    Default NeoBoot by 'gutosie' 6.53
    Supported tuners: All VuPlus models - clones too, Octagon SF4008, MiracleBox Mini, Formuler (Tests - DM900)
    NeoBoot is not yet fully functional in the DM900 and OctagonSF4008 models - work on the improvement is underway ...
    The first neoboot installation
    Run the following command in the supported tuner terminal:
     opkg update
    opkg install curl
    curl -kLs https://raw.githubusercontent.com/gutosie/neoboot/master/iNB.sh|sh
    WARNING!!! Redistribution of the program version and making modifications IS PERMITTED subject to the observance of this copyright notice.
    The author DOES NOT bear ANY responsibility for the consequences of using this program and for the use of the information contained herein.
    You carry out the installation and modifications at your own risk !!! Before installing or updating Neoboot read carefully all information contained here and in the plugin. !
    Thank you to all my colleagues supporting the neoboot project.
    gutosie
    Download [Only Registered Users Can See Links. Click Here To Register]
    :download:
  2. #12
    Join Date
    Aug 2010
    Posts
    17,180
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    78
    Default
    VU+NeoBoot by gutosie 6.54
     opkg update
    opkg install curl
    gutosie
    [*]ver 6.54 dodano Axas E4HD 4K i Maxdigital XP1000 Download [Only Registered Users Can See Links. Click Here To Register][/list] DOWNLOAD [Only Registered Users Can See Links. Click Here To Register]
  3. #13
    Join Date
    Aug 2010
    Posts
    17,180
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    78
    Default
    VU+NeoBoot 6.55 by gutosie
    • ver 6.55 dodano Qviart lunix3-4k
    gutosie'
    Wspierane tunery: Wszytkie modele VuPlus - klony też, Octagon SF4008, MiracleBox Mini, Formuler, Edison Mini OS ( Testy- DM900)
    NeoBoot nie działa jeszcze w pełni sprawnie w modelach DM900 i OctagonSF4008 - prace nad ulepszeniem trwają..
    Pierwsza instalacja neoboot-a
    Uruchom poniższą komendę w terminalu wspieranego tunera:
    opkg update
    opkg install curl
    UWAGA!!! Redystrybucja wersji programu i dokonywania modyfikacji JEST DOZWOLONE, pod warunkiem zachowania niniejszej informacji o prawach autorskich.
    Autor NIE ponosi JAKIEJKOLWIEK odpowiedzialności za skutki użytkowania tego programu oraz za wykorzystanie zawartych tu informacji.
    Instalację i modyfikacje przeprowadzasz na wlasne ryzyko!!! Przed instalacją lub aktualizacją Neoboot przeczytaj uważnie wszystkie informacje zawarte tu i w wtyczce. !
    Dziękuję wszystkim kolegom wpierającym projekt neoboot.
    Dziękuję też kolegom wspierającym projekt.
    pozdrawiam gutosie
    [Only Registered Users Can See Links. Click Here To Register] komenda z konsoli żeby ruszyło z flasha
    mount -a
    ln -sf "init.sysvinit" "/sbin/init"
    echo "Flash " > /media/neoboot/ImageBoot/.neonextboot
    :download:
  4. Thanks rselturk thanked for this post
  5. #14
    Join Date
    Jul 2014
    Posts
    2
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    0
    Default
    i created a backup with neoboot backup option.
    backup is found but there is no option to restore in neoboot.
    how can i restore a backup?
  6. #15
    Join Date
    Apr 2007
    Location
    Denmark
    Posts
    13,223
    Post Thanks / Like
    Downloads
    21
    Uploads
    7
    Rep Power
    10
    Default
    According to the German instructions , the backup file schould be renamed to : kernel_auto.bin , and installed via usb .
    I did it my way
  7. #16
    Join Date
    Jul 2014
    Posts
    2
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    0
    Default
    Quote Originally Posted by LilleMama View Post
    can u explain more as i cant understand how a kernel-auto.bin can be installed via usb.?
  8. #17
    Join Date
    Aug 2010
    Posts
    17,180
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    78
    Default
    NeoBoot 7 test by gutosie
    duo4k and others have been added I wrote gutos, I have one hdd and one pena (one partition) and in my case fstab looks like this:
     rootfs / auto defaults 1 1
    proc / proc proc defaults 0 0
    devpts / dev / pts devpts mode = 0620, gid = 5 0 0
    usbdevfs / proc / bus / usbdevfs noauto 0 0
    tmpfs / var / volatile tmpfs defaults 0 0
     UUID  = 7d1c6g7d-5bba5-405b-a152-00t44ae8ea2 / media / hdd auto defaults 0 00
     UUID  = 3co5d86c-07e3-4008-a1d7-c408vcbec1ar / media / usb  auto defaults
    with this set you have to have only two lines UUID
    and still in the location / usr / lib / enigma2 / python / Plugins / Extensions / NeoBoot / bin in the file named install should be the same content as it is installed neo, i.e. in me / media / usb
    / dev / sda1: LABEL = "usb" UUID = " 3co5d86c-07e3-4008-a1d7-c408vcbec1ar " TYPE = "ext4"
    it's a string of digits and numbers after " UUID = "to " TYPE = "ext4" [/ COLOR]
    how is it different you did something wrong
    [Only Registered Users Can See Links. Click Here To Register] Download [Only Registered Users Can See Links. Click Here To Register]
  9. Thanks taree thanked for this post
  10. #18
    Join Date
    Aug 2010
    Posts
    17,180
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    78
    Default
    NeoBoot 7.03 by gutosie
    Wspierane tunery:
    • Wszytkie modele VuPlus - klony też,
    • Octagon SF4008,
    • Octagon SF8008,
    • Zgemma h7S,
    • MiracleBox Mini,
    • Formuler,
    • Edison Mini OS
    • (Testy- DM900)
    :download:
  11. Thanks taree thanked for this post
  12. #19
    Join Date
    Aug 2010
    Posts
    17,180
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    78
    Default
    NeoBoot 7.04 by gutosie
    Wspierane tunery:
    1. [*]et8500
    2. SF4008
    3. Ultimo4k
    4. Ultimo
    5. Zero
    6. OSmini
    7. Formuler F1
    8. MBmini
    9. Solo4k
    10. Uno
    11. Solo
    12. Duo4k
    13. Formuler F3
    14. atemio6000
    15. Uno 4K
    16. Duo2
    17. Solose-v2
    18. Zgemma h7S
    19. MBmini
    20. Miraclebox Micro
    21. Uno4kSE
    22. Duo
    23. Solose
    24. Octagon Sf8008
    25. Miraclebox Ultra
    26. Zero 4K
    27. Solo2
    28. Zgemma H9S
    :download:
  13. Thanks taree thanked for this post
  14. #20
    Join Date
    Aug 2010
    Posts
    17,180
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    78
    Default
    NeoBoot 7.05 by gutosie
    Wspierane tunery:
    1. et8500
    2. SF4008
    3. Ultimo4k
    4. Ultimo
    5. Zero
    6. OSmini
    7. Formuler F1
    8. MBmini
    9. Solo4k
    10. Uno
    11. Solo
    12. Duo4k
    13. Formuler F3
    14. atemio6000
    15. Uno 4K
    16. Duo2
    17. Solose-v2
    18. Zgemma h7S
    19. MBmini
    21. Uno4kSE
    22. Duo
    23. Solose
    24. Octagon Sf8008
    26. Zero 4K
    27. Solo2
    28. Zgemma H9S
    :download:
  15. Thanks taree, kraibi thanked for this post
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
