Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: faulty motor
  1. #11
    Join Date
    Oct 2008
    Posts
    9
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    0
    Default motor was faulty
    Hi all
    the motor was at fault and has been returned for repair/replacement under waranty
    thanks for all replys
  2. #12
    Join Date
    Oct 2008
    Posts
    9
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    0
    Default motor wont move
    Hi
    The motor has been found OK so what is making the motor switch off when I send a command...If I bypass motor I can recieve channels
  3. #13
    Join Date
    Oct 2008
    Posts
    9
    Post Thanks / Like
    Downloads
    0
    Uploads
    0
    Rep Power
    0
    Default Help me
    Hi all
    I still need help bigstyle so posting again
    Everything was working fine until I decided to try a different image.
    After erasing image and then reflashing with various images the latest one Nabilosat darkstar II image, I could not get the motor to turn but it will turn by manually pressing E/W buttons. I have factory reset the box and reset the motor but everytime I try to set up the motor by entering LAT and LONG the lights on the motor go out when I go to the next page of setup and also everytime a signal is sent to the motor, and I have to reboot to get the lights back on.
    The motor has been tested and it is OK. Using a meter the power goes from 10v to 17v when I send a signal to the motor which I think is OK. If I bypass the motor I can receive channels.
    I unfortunately did not backup before flashing
    Am I missing something? Do I need to install anything else?
    Any help would be greatly appreciated PLEASE
    Cheers
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
