Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: IncubusCamd
  1. #31
    Join Date
    Oct 2007
    Location
    Athens,Greece
    Posts
    1,166
    Post Thanks / Like
    Downloads
    1
    Uploads
    0
    Rep Power
    10
    Default
    IncubusCamd v.1.10 (added server functionality)
    25/05/2010, V1.10
    - fixed Conax EMMs
    - added server functionality/multiclient support for cccam protocol (this means you can use the incubusCamd as a server):you can also reshare your local card if connected as newcamd/radegast client (see the config file for more info, [Clients] section and
    all over the config for other special customizations)
    [Only Registered Users Can See Links. Click Here To Register]
    DREAMBOX 8000 HD
    VU+DUO HD
    IP BOX 9000 HD
    All files and posts are for educational purposes only... !!!
  2. #32
    Join Date
    Oct 2007
    Location
    Athens,Greece
    Posts
    1,166
    Post Thanks / Like
    Downloads
    1
    Uploads
    0
    Rep Power
    10
    Default
    IncubusCamd v.1.15
    11/06/2010, V1.15
    - fixed a bug on clients' filters
    - improved dw searching if timeshift and PIP enabled
    - added -help option, -config-file option, -debug-level option given as parameter to the executable file
    - fixed some info on the webif (more need to be added/fixed)
    - fixed some problems with clients connection and few CCcam versions
    - added channel info file (used in the webif, but this feature in the webif is still missing)
    - added provider info file (used in the webif)
    DREAMBOX 8000 HD
    VU+DUO HD
    IP BOX 9000 HD
  3. #33
    Join Date
    Oct 2007
    Location
    Athens,Greece
    Posts
    1,166
    Post Thanks / Like
    Downloads
    1
    Uploads
    0
    Rep Power
    10
    Default
    IncubusCamd v.1.15
    12.06.2010
    incubusCamd-1.15 for Sif Image
    DREAMBOX 8000 HD
    VU+DUO HD
    IP BOX 9000 HD
  4. #34
    Join Date
    Oct 2007
    Location
    Athens,Greece
    Posts
    1,166
    Post Thanks / Like
    Downloads
    1
    Uploads
    0
    Rep Power
    10
    Default
    IncubusCamd v1.16
    12/06/2010
    - fixed a memory leak bug on cccam connections
    - added in webif ecm requests information for clients/servers
    - fixed multidescrambling on enigma2 for sh4
    DREAMBOX 8000 HD
    VU+DUO HD
    IP BOX 9000 HD
  5. #35
    Join Date
    Oct 2007
    Location
    Athens,Greece
    Posts
    1,166
    Post Thanks / Like
    Downloads
    1
    Uploads
    0
    Rep Power
    10
    Default
    IncubusCamd v1.17
    04/07/2010,
    - fixed a bug for cuberevo-digital firmwares on setting pids
    - fixed another bug on multidescrambling on enigma2 firmwares
    DREAMBOX 8000 HD
    VU+DUO HD
    IP BOX 9000 HD
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
