How Black Harmony Skin Installation NOTE: By following all the points described below, you gain access to ongoing skin updates and the UserSkin plugin
along with software updates for the software used. Insofar as they will be made public.
How UserSkin plugin
To start, REMEMBER how to deal with problems with any skin, such as a looped start or similar:
1. Connect to the tuner via ftp, if reinstall does not work soft!
2. if the directory / usr / share / enigma2 / / mySkin exists, delete it and reboot the tuner
3. if the above did not help, enter the / etc / enigma2 / directory and delete all files with the name "skin_user" and the extension xml in the name and finally restart the tuner
4. if it didn't help, change the name or delete the entire skin directory, i.e. / usr / share / enigma2 /, restart the tuner.
NOTE: after this operation the tuner will return to the standard skin
5. if it did not help, the last chance step is to change the name (for no treasures we can delete, it can be useful) in the file / etc / enigma2 / settings for another one and restart the tuner.
ATTENTION: after this operation the tuner will start as if it had just been installed
6. Finally, but always, we always give the author a skin on the dvhk forum in the thread about the skin:
· What returns the "opkg list-installed | grep j00zek; ls / usr / share / enigma2 /; ls / usr / share / enigma2 / BlackHarmony / UserSkin_Selections /" command issued on telnet
· GS log from the / hdd directory, because only this log can help in removing the error
Installation of the opkg repository for VTI, Vu Open Embeded, openPLi, BlackHole:
ATTENTION: Although the skin effect on BlackHole has been confirmed by one of the users, it is recommended for inexperienced to use only standard skins! BlackHole is a system practically unused by others and there is a small chance of getting help in case of any problems.
1. Download the file http://j00zek.one.pl/opkg-j00zka/j00...ed_1.2_all.ipk
2. upload to / tmp
3. launch the terminal (e.g. putty)
4. issue the command "opkg install /tmp/j00zeks-opkg-feed_1.2_all.ipk;" (WE DO NOT ENTER FOREIGNERS !!!)
5. Optional if you want to be able to install add-ons from the remote control
a. issue the command "opkg update; opkg install enigma2-plugin-extensions - j00zeks-j00zekopkgmgr;" (WE DO NOT ENTER FOREIGNERS !!!)
b. restart the tuner
Activating the opkg repository for openATV:
1. The green key or menu item "plugin browser"
2. While in the plug-in browser, press the "menu" key
3. At the very bottom is "user feed url" where you enter:
· Code: user feed url = http://j00zek.one.pl/opkg-j00zka/
· The word "j00zka" has two zeros, in words: zeros, do not enter like Ola, only zeros
· After entering the url from point 3 press the green "save" button
4. Optional if you want to be able to install add-ons from the remote control
a. start the terminal (e.g. putty)
b. issue the command "opkg update; opkg install enigma2-plugin-extensions - j00zeks-j00zekopkgmgr;" (WE DO NOT ENTER FOREIGNERS !!!)
c. restart the tuner
Installation of the "Black Harmony mod j00zek" skin and other add-ons from the remote control:
1. Access the plug-in browser
2. Enter the "OPKG Alternative Manager" plugin
3. Select 'Prepared by j00zka and friends'
4. Install the blackharmonyfhd skin
5. Optionally install the userskin plugin (needed to select additional screens)
6. Optionally install the msnweather-np plugin (needed to display weather data)
(Re) Installation of the "Black Harmony mod j00zek" skin from the terminal:
1. start a terminal (e.g. putty)
2. issue the command "opkg update; opkg install --force-reinstall enigma2-plugin-extensions - j00zeks-userskin enigma2-plugin-skins - j00zeks-blackharmonyfhd;"
3. Optional if you want to install / reinstall the weather plugin
a. issue the command "opkg install --force-reinstall enigma2-plugin-extensions - j00zeks-msnweather-np;"
4. Select a skin in the menu
Activation of "Black Harmony mod j00zek" skin additions:
1. In VTI enter Menu -> Configuration -> System -> ’UserSkin’ - for BlackHarmony skins
2. In OpenATV, enter Menu -> Configuration -> Operation and Interface -> ’UserSkin’ - for BlackHarmony skins
3. In OpenPLi7 enter Menu -> Settings -> System -> ’UserSkin’ - for BlackHarmony skins
4. Set "Activate skin personalization" to Yes
5. Under the yellow button select interesting modifications
6. After exiting the modification selection mode, press the green key
7. If no errors were reported, confirm the restart
How UserSkin plugin
2. upload to / tmp
