Handling the skins a small description
  • Handling the skins a small description
    Handling the skins a small description that you do not need to upload a new software every time. In 99% of cases, the following will help.
    Procedure in case of problems with any skin (except standard, but this must work correctly), such as looped start or similar:
    We do everything via ftp. If it does not work, we will reinstall soft!
    1. if there is a directory / usr / share / enigma2 / / mySkin delete it and restart the tuner,
    2. if the above did not help, go to the directory / etc / enigma2 / and delete all the files with the "skin_user" member and the xml extension and finally restart the tuner
    3. if it did not help, change the name, or delete the whole skin directory, ie / usr / share / enigma2 / , restart the tuner. NOTE: after this operation, the tuner will return to the standard skin
    4. if it did not help, the last chance step is to change the name (we can not delete this file for any treasure) file / etc / enigma2 / settings to some other one and restart the tuner. NOTE: after this operation, the tuner will start up as if it had just been installed soft
