Description faked Oscama You download oscam from FEDC with sat 4 all (I gave the link only the moderator removed the link) unpack the npcam for a new oscam you change it to the same name as you have already uploaded oscam 7cam, oscam 7119, slaughter oscam or run other than oscam 7119 which swapped you will (you do not delete the old file uploaded (the file overwrites), you need, for example, TotalCommander and send a downloaded oscam via FTP, you log in to the decoder. You select [network then [FTP New Connection, enter the decoder IP ( current)] eg 192.168.1.111] delete a bird in an anonymous connection [confirm ok] enter user [/ U] root confirm ok enter password if you have, if not (you do not enter anything) confirm ok after logging in simply send the downloaded oscam to [var / bin or according to the directory in which is oscam depending on the immage you will sign up to start old oscam 7119 a works the latest downloaded oscam.
