VU + Animation picon in skin BlackHarmony and SKIN BLACK FHD PLi v1.5 by Mercus34 Des
  • VU + Animation picon in skin BlackHarmony and SKIN BLACK FHD PLi v1.5 by Mercus34 Des
    VU + Animation picon in skin BlackHarmony and SKIN BLACK FHD PLi v1.5 by Mercus34 Description by zdzislaw22
    This renderer for animated picon display behaves the same as those from xpicon or zzpicon, i.e. it automatically searches for the animated picon catalog in / usr / share / enigma2 and in the roost of each mounted device.
    So how do you have, for example, mounted drive to / hdd and create in it an animatedPicons to renderer directory will use it if there is no directory / usr / share / enigma2 / animatedPicons
    And the options you noticed are used to force a specific picon. If you're a collector and have several different animations, you can use these options to force the renderer to use only those you have chosen. In other words, you can have an animation in any directory and choose which one to use.
    _________________ _ example Activate user's path and I have No
    User path and mam usr / share / enigma 2 34/5000
    FILM We choose Infobars in userskin
    The picon animation mode I have Controlled by the skin. TU
    animatedZZPicons.z
    https://www.sendspace.com/file/c8iq67 TU line to paste for skina xml Copy of the description from the renderer:
    Quotation:
    # Renderer for Enigma2
    # Coded by j00zek (c) 2018
    # Respect my work and do not delete / change information who is the author of the renderer
    # Please respect my work and do not delete / change name of the renderer author
    # This program is free software; you can redistribute it and / or
    # modify it under the terms of the GNU General Public License
    # as published by the Free Software Foundation; either version 2
    # of the License, or (at your option) any later version.
    # This program is distributed in the future,
    # but WITHOUT ANY WARRANTS; without even the implied warranty of
    # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    # GNU General Public License for more details.
    # To use it to the following:
    # - download package of animated picons, for example from my opkg
    # - write them in the animatedPicons folder on mounted device or in / usr / share / enigma2 /
    # NOTE: if you want to use any other folder, you need to specify it in the widget definition. E.g. pixmaps = "animatedPicons / flare /"
    # - include J00zekPiconAnimation widget in the infobar skin definition.
    # E.g.
    # NOTE:
    # - position = "X, Y" should be the same as position of a picon in skin definition
    # - size = "X, Y" should be the same size of a picon in skin definition
    # - zPosition = "Z" should be bigger than zPosition of a picon in skin definition, to display animation over the picon.
    VU+animated-matrix-xpicon-size-220x132 by Adek Na skina BlackHarmony oraz SKIN BLACK FHD PLi v1.5 by Mercus34 Download http://j00zek.one.pl/opkg-j00zka/eni...3.1630_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk Download http://j00zek.one.pl/opkg-j00zka/eni...2.0739_all.ipk
