HOW NOTE: By following all the points described below, you gain access to current ski
  • HOW NOTE: By following all the points described below, you gain access to current ski
    HOW NOTE: By following all the points described below, you gain access to current skin and UserSkin plugins updates
    along with software updates of the used software. If they are made public.
    At the beginning, REMEMBER how to deal with problems with any skin, such as a looped start or similar:
    1. Connect to the tuner via ftp, when it does not work re-install soft!
    2. if there is a directory / usr / share / enigma2 / <Skin name> / mySkin delete it and restart the tuner
    3. if the above did not help, go to the directory / etc / enigma2 / and delete all files with the "skin_user" name and the xml extension in the name and finally restart the tuner
    4. if it did not help, change the name, or delete the whole skin directory, ie / usr / share / enigma2 / <Skin name>, restart the tuner.
    NOTE: after this operation, the tuner will return to the standard skin
    5. if it did not help, the last chance step is change the name (we do not delete any treasures, it may be useful) to the / etc / enigma2 / settings file on some other one and restart the tuner.
    NOTE: after this operation, the tuner will start up as if it has just been installed soft
    6. At the end of it always but always we always give the author a skin on the forum dvhk in the thread about the skin:
    · What returns the command "opkg list-installed | grep j00zek; ls / usr / share / enigma2 /; ls / usr / share / enigma2 / BlackHarmony / UserSkin_Selections /" published on telnet
    · GS log from / hdd directory, because only this log can help in removing the error
    Installation of opkg repository for VTI, Vu Open Embeded, openPLi, BlackHole:
    NOTE: Although the operation of the skin on BlackHole has been confirmed by one of the users, it is recommended that inexperienced use only standard skins! BlackHole is a system practically unused by others and there is little chance of getting help in case of any problems.
    1. download the file http://j00zek.one.pl/opkg-j00zka/j00...ed_1.2_all.ipk
    2. upload to / tmp
    3. start the terminal (eg putty)
    4. issue the command "opkg install /tmp/j00zeks-opkg-feed_1.2_all.ipk;" (WE DO NOT ENTER THE MIRACKS !!!)
    5. Optionally, if we want to be able to install add-ons from the remote control
    a. issue the command "opkg update; opkg install enigma2-plugin-extensions - j00zeks-j00zekopkgmgr;" (WE DO NOT ENTER THE MIRACKS !!!)
    b. restart the tuner
    Activation of opkg repository for openATV:
    1. Green key or from the menu you choose "plug-in browser"
    2. Being in the plug-in browser, press the "menu" key
    3. At the very bottom is "user feed url" where you enter:
    · In the word "language" there are two zeros, in words: zero, do not enter like Ola, only zero
    · After entering the url from point 3 press the green "save" key
    4. Optionally, if we want to be able to install add-ons from the remote control
    a. start the terminal (eg putty)
    b. issue the command "opkg update; opkg install enigma2-plugin-extensions - j00zeks-j00zekopkgmgr;" (WE DO NOT ENTER THE MIRACKS !!!)
    c. restart the tuner
    Installation of the "Black Harmony mod j00zek" skin and other additions from the remote control:
    1. Access the plug-in browser
    2. Go to the "Alternative OPKG manager" plugin
    3. Select the option "Prepared by your friend and friends"
    4. Install the blackharmonyfhd skin
    5. Optionally install the userskin plugin (needed to select additional screens)
    6. Optionally, install the msnweather-np plugin (needed to display weather data)
    (Re) Installation of the "Black Harmony mod j00zek" skin from the terminal:
    1. start the terminal (eg putty)
    2. issue the command "opkg update; opkg install --for-reinstall enigma2-plugin-extensions - j00ex-userskin enigma2-plugin-skins - j00ex-blackharmonyfhd;"
    3. Optionally, if you want to install / reinstall the weather plug-in
    a. issue the command "opkg install --force-reinstall enigma2-plugin-extensions - j00zeks-msnweather-np;"
    4. Select the skin in the menu
    Activation of the "Black Harmony mod j00zek" skin additions:
    1. In VTI enter Menu -> Configuration -> System -> 'UserSkin' - for BlackHarmony skin
    2. In OpenATV enter the menu -> Configuration -> Service and Interface -> 'UserSkin' - for the BlackHarmony skin
    3. In OpenPLi7 enter the menu -> Settings -> System -> 'UserSkin' - for the BlackHarmony skin
    4. Set "Activate skin customization" to Yes
    5. Choose interesting modifications under the yellow button
    6. After exiting the modification selection mode, press the green key
    7. If no errors have been reported, confirm the restart
    Access to "frozen" packages is possible only after activating opkg in the tuner
    Download the https://github.com/j00zek/eePlugins plugin here
