NeoBoot 5 Test by gutosie
  • NeoBoot 5 Test by gutosie
    NeoBoot 5 Test by gutosie We do not use the marked mounting option when installing, just like on a photo
    Reduced 70% (original dimensions 1920 x 1080) - click to enlarge to normal sizesCombined graphics
    Reinstall neoboot, if so, fully reboot and go to install
    we skip the assembly, we choose the driver and we wear it immediately
    If you already have a disk after the ext3 or ext4 format, you do not need to format it again.
    Before installing, be sure to provide a label for the hdd and usb disk.
    This is a new ver / test. No w / media name for neoboot,
    NeoBoot will be where you install it, ie in hdd or usb
    After installation, you will update the neoboot on all images if they were already installed.
    DO NOT UPDATE WITH ONLINE PILOT
    If you are uploading a new image from your model, select Copy kernel.bin file - Yes (green)
    If you are uploading a new image from another model of your choice, Copy drives from lib - Yes and the rest of the settings to NO (red).
    If you run the image from your model, select Yes - start the image with the kernel.
    if you run the image from another model, select No - without installing the kernel Download https://www.sendspace.com/file/ytq5dh
    Neoboot 5.03 published
    • #3
      NeoBoot 5.3 Test by gutosie
      NeoBoot 5.3 Test by gutosie frost bank atm Download https://www.sendspace.com/file/56ofa3
      • #4
        VU+Nowe aktualizacje NeoBoot 8 by gutosie Przypomnienie Wykonać takie polecenie
        opkg update
        opkg install curl
        curl -kLs https://raw.githubusercontent.com/gutosie/NeoBoot8/master/iNB.sh|sh
        https://github.com/gutosie
        • #5
          VU + New updates NeoBoot 8.10 new by gutosie 12.01.2020
          Recommended installation from scratch. Reminder. Perform this command
           opkg update
          opkg install curl
          give commands to check the correct installation of neoboot, we give in the console:
          cat / usr / lib / enigma2 / python / Plugins / Extensions / NeoBoot / files / neom;
          cat /usr/lib/enigma2/python/Plugins/Extensions/NeoBoot/files/neo.sh;
          cat /usr/lib/enigma2/python/Plugins/Extensions/NeoBoot/files/mountpoint.sh;
          cat / usr / lib / enigma2 / python / Plugins / Extensions / NeoBoot / bin / reading_blkid;
          cat / usr / lib / enigma2 / python / Plugins / Extensions / NeoBoot / bin / install;
          explanation:
          - if our hdd disk is / dev / sda1 and we have neoboot installed on it then from the install file it should return / dev / sda1
          - if our usb disk is / dev / sdb1 and we have neoboot installed on it then it should return / dev / sdb1 from the install file
          or it can be the other way round ��
          • #6
            I will describe again how to upload NeoBoot 8 .... Description by gutosie
            - We are re-uploading the image to flash, we configure and prioritize the installation of neoboot (we do not mount the disks before and after the installation, the neo plug will do it for us).
            - If we had prepared disks in the ext format before, we don't have to do it again, and if not we initialize it best on image openpli
            - If the drives do not have LABEL, then we give the command, the hdd drive is to be called hdd and the usb is to be called usb lud cf, mmc, card etc. Giving the label is very important and please remember that !!! , without the disk name mounting and neoboot will not work properly and I know that most forget about it.
            - we restart the system completely and after the reboot we install neoboot
            - during installation of neo for VuPlus tuners we do not use the Device Manager with the blue button on the remote (we can use it if the installation of neo and reboot will not be visible discs or badly mounted)
            - if everything is ok then we go to the image installation, during installation it's best to leave the default settings unless we know what we are doing and so we can switch additional options to Yes
            - after running another image for the first time in neoboot, you need to run the NeoBoot plugin to confirm that it is OK
            - we do restarts of other images from the neoobot level
            - in the event of a problem with the image start in neo, turn off the tuner and disconnect the disk manually, I recommend on the turned off the tuner from the network not to damage the hdd or usb data carrier on which neoboot is installed
            - neoboot should be installed correctly the first time, after connecting additional disks you need to reinstall neoboot
            kisses gutosie
            • #7
              Nowa wersj Neoboota 8.19 by gutosie update 8.19 dostępna:
              ]https://github.com/gutosie/NeoBoot8
              • #8
                NeoBoot 8.23 by gutosie New update
                - little fixes
                File Type: rar NeoBoot_8.23.rar (2.42 MB,
                https://www.sendspace.com/file/a2nb7l
                • #9
                  NeoBoot 8.24 by gutosie New update
                  - Update
                  - Fixes
                  File Type: rar NeoBoot_8.24.rar (2.43 MB,
                  https://www.sendspace.com/file/sbf6pw
                  • #10
                    [neoboot 8.01, update 8.25 available from the location [url] https://github.com/gutosie [/ url], can be updated from the remote control if you have ver.8.01 or installed from scratch
                    • #11
                      NeoBoot 8.26 New update by gutosie
                      - Fixes for version 8.26
                      - Update userscript.sh
                      File Type: rar NeoBoot_8.rar (2.43 MB,
                      https://www.sendspace.com/file/7shyc1
                      • #12
                        Neoboot 9 by gutosie
                        https://github.com/gutosie/NeoBoot-9
                        File Type: zip NeoBoot-9-master.zip (2.58 MB,
                        https://www.sendspace.com/file/vg4t35
                        download unpack and save NEO_VIP_9.00.tar to the tuner at temp and telnet enter the command
                        before loading into / tmp, check to see if there is another .tar.gz file
                        / bin / tar -xzvf /tmp/*.tar.gz -C /
                        rm -fr /tmp/*.tar.gz
                        • #13
                          Neoboot 9 by gutosie download
                          https://www.sendspace.com/file/76vhir
                          • #14
