enigma2-plugin-extensions-xtraevent v3.1
  • enigma2-plugin-extensions-xtraevent v3.1
    xtraEvent 3.1
    File Type: ipk enigma2-plugin-extensions-xtraevent_v3.1_all.ipk (2.56 MB, https://uploadfile.pl/pokaz/2181084---ummp.html
    [Plugin] xtraEvent Update V3.2
    some fixes...
    xtraNextEvents changed..added skinpart for poster...skin_ChannelSelection-xtra-5.xml
    Thx @ digiteng
    File Type: zip enigma2-plugin-extensions-xtraevent_v3.2_all.zip‎ (2.61 MB, https://uploadfile.pl/pokaz/2181219---9lno.html
    • #3
      xtraEvent 3.3
      - xtraStar.py codes changed ...
      without changing the skin code ...
      - some fixes
      File Type: ipk enigma2-plugin-extensions-xtraevent_v3.3_all.ipk (2.62 MB https://uploadfile.pl/pokaz/2181490---xmgw.html
