E2m3u2bouquet Plugin (Mod Dorik1972)
  • E2m3u2bouquet Plugin (Mod Dorik1972)
    -05.09.2021-
    From the autor:
    "Completely redesigned pattern regex-pa for m3u parsing ... now it works ~1sec faster for 800-1000 processed records
    The theory says that if we do re. compile () for union, i.e. like this re. compile ('timeshift|tvg-tec|tvg-id|tvg-name|tvg-logo'), then rewriting it like this-re. compile ('t(?:imeshift|vg\ - (?: id|logo|name|rec))')... we will get an increase in speed by hundreds of times"
    File Type: zip enigma2-plugin-extensions-e2m3u2bouquet_1.0.43_all.ipk.zip‎ (1.05 MB, https://uploadfile.pl/pokaz/2170881---t2d5.html
    File Type: zip enigma2-plugin-extensions-e2m3u2bouquet_1.0.43_all.deb.zip‎ (969.0 KB,https://uploadfile.pl/pokaz/2170880---mnyn.html
    enigma2-plugin-extensions-e2m3u2bouquet Fixes for Version 1.0.43
    ..small fix for "recognizing" the encodings "slipped" by m3u"
    Enter your link to download the EPG in the plugin config..
    File Type: rar enigma2-plugin-extensions-e2m3u2bouquet_1.0.43_all.ipk.rar (1.06 MB, https://uploadfile.pl/pokaz/2173046---llw0.html
    • #3
      enigma2-plugin-extensions-e2m3u2bouquet Version 1.0.44
      FIX wakeup timer ..... who updated yesterday - update again
      File Type: ipk enigma2-plugin-extensions-e2m3u2bouquet_1.0.44_all.ipk (1.07 MB, https://uploadfile.pl/pokaz/2174358---7vp9.html File Type: deb enigma2-plugin-extensions-e2m3u2bouquet_1.0.44_all.deb (972.0 KB, https://uploadfile.pl/pokaz/2174359---qh4t.html
