XStreamity 2.9902 (beta)
  • XStreamity 2.9902 (beta)
    File attached for testing.
    New time values for player infobar using a version of openatv SCServiceposition.py component. All images show something different with their default serviceposition.py module.
    Removal of twisted downloadpage and instead use of my own custom threaded downloader. Should eliminate https hacks, SSL problems and seperate python3 code.
    Better image handling for picons and covers
    Parental control - only asks for pin every 15 mins now.
    Ignores "allgemeines" from parental control "all" check.
    Fixed hidden channels reseting if another bouquet/category was edited.
    Removed custom epg url - People didn't like domain/username/password being shown - user would now have to amend this url in the json file for the very few that don't have a proper epg url.
    Removed full get.php url from info screen - for security reasons - see above
    Streams are now forced stopped before playing next stream on zapping to help prevent stream freezes if the stream wasn't released quick enough.
    If image doesn't have up to date requests or urllib3 library - it safely fallbacks to an alternative
    Removed manual update of catchup channel list - just rechecks channels that have catchup every time on entering plugin now.
    Removed manual epg timeshift - (may no longer be required)
    Removed manual catchup timeshift - (may no longer be required)
    Added a reverse list option to catchup list times. Ascending / Descending.
    Removed some logic that checked streams were valid or had stopped - i think it was causing more problems than solving
    Changed default timeout to 6 seconds (it used to be 3)
    Corrected TMDB director names. It wasn't showing the director previously. Oops.
    Updated English po/mo files
    AND THE BIG CHANGE - NEW FULL EPG - EPG IMPORTER NOT REQUIRED**
    Due to on going problems with EPGs, I have tried something completely new. (again). Or more accurately copied lots of code from epg importer.
    Unfortunately this means I have removed the old quick epg again (enigma2.php), and also removed the epg importer import of epg.
    Full EPG downloads on entering live category.
    First time this download and processing might take about 1 min. No need to exit plugin as it should refresh epg lists when download complete.
    If you use XStreamity on a daily basis. Then the EPG should be pre-loaded and instant after first initial download.
    If its been a couple of days or more since you last used xstreamity then you will have to wait until the epg downloads again. (This is similar to what android IPTV apps do)
    I have studied a few EPG times and offsets. I think I have worked out all the automation for this for the differences in UTC times, local times, British Summer times, server times etc.
    Any existing timeshift offset query strings in your playlists.txt file will be ignored for now.
    Still some things I want to change, but lets put it out there to see how it plays on various different images.
    Most things should download in the background, but the way python works there will be the occasional lag or temp freeze as it processes large stuff in the background. Thats just the way it is.
    It might be safer but I don't think 100% required to delete your existing json file
    /etc/enigma2/xstreamity/x-playlists.json
    File Type: ipk enigma2-plugin-extensions-xstreamity_2.9902.20210809_all.ipk (1.92 MB, https://uploadfile.pl/pokaz/2166867---enq2.html
    XStreamity 2.9903 (beta)
    -catchup option now fixed.
    -Also added the seconds back on infobar
    Thanks KiddaC
    File Type: ipk enigma2-plugin-extensions-xstreamity_2.9903.20210811_all.ipk (1.92 MB,https://uploadfile.pl/pokaz/2167016---rtbc.html
    • #3
      XStreamity 2.9906 (beta)
      KiddaC wrote
      tweaked manual playlist entry. it was crashing if username or password was incorrectly entered and provider (xui_one panels) shows an error splash screen instead. It was fine if username and password were correct.
      tweaked change aspect ratio (green button) for those boxes that allow it. My multiboot box vu zero 4k doesn't so difficult for me to test. Says apsect ratio changed, but nothing visually changes.
      This is a completely different approach for this, with code borrowed from MyStreamVod plugin.
      tweaked the VOD stream progress times, basing it now on openvix serviceposition.py but stripped down. No reference to config settings, so should be universal and not box specific.
      File Type: ipk enigma2-plugin-extensions-xstreamity_2.9906.20210814_all.ipk (1.92 MB, https://uploadfile.pl/pokaz/2167387---bpyl.html
      • #4
        XStreamity v3.01
        Should now work on VTI 15 images. (or does on vti 15 on my vu zero 4k - note you definitely need install ffmpeg to play videos on that image)
        Different threading module used for all my background processes. (all images)
        Fixed some code errors
        Not fixed blackhole yet. (or even think I can without reverting back to old code)
        @Kiddac
        File Type: ipk enigma2-plugin-extensions-xstreamity_3.01.20210819_all.ipk (1.92 MB, https://uploadfile.pl/pokaz/2168013---tbvu.html
        • #5
          XStreamity v3.05
          • added new italian, portuguese, arabic language files
          • fixed python 2, blackhole, dreambox and maybe VTI background EPG download.
          • picons, covers, files should all now download correctly
          • playlist menu page has been changed to sequentially downloading of the 4 files needed to display, live, vod, series, catchup categories.
          • XStreamity appears in main menu by default, can be removed in main settings.
          Thx @ KiddaC & Linuxsat
          Dreambox 500s & 800 HD_800 SE _Cristor Atlas E_ATLAS HD 100 ATLAS HD 200s_Morebox_Aston simba 202s _ Stream Bm350cas_
          Starsat7100 usb et 7300cu super _
          DC 3000_Omnia+Samsat HD70
          • #6
            X-Streamity-V 3.06
            Images that can process the EPG in the background with minimum freezing now do so.
            Older images you are still going to get about a 10-30 second freeze. Depending on the size of your epg file.
            I have been trying to find a work around for these older images... no success yet.
            Added in new dutch Language files.
            Added in new no frills transparent FHD skin called haze. (it has no mini tv)
            Thx @KiddaC
            • #7
              XStreamity 3.07
              KiddaC wrote
              Just getting openatv 7.0 working again.
              No other changes in this update.
              Thanks KiddaC
              File Type: ipk enigma2-plugin-extensions-xstreamity_3.07.20210826_all.ipk (1.96 MB, https://uploadfile.pl/pokaz/2169308---hzt2.html File Type: deb enigma2-plugin-extensions-xstreamity_3.07.20210828_all.deb (1.76 MB, https://uploadfile.pl/pokaz/2169310---9826.html
              • #8
                XStreamity v.3.08
                g?ncellemesi.
                enigma2-plugin-extensions-xstreamity_3.08.20210828_all.ipk
                (4.29 MB, https://uploadfile.pl/pokaz/2169574---fkpc.html
                • #9
                  enigma2-plugin-extensions-xstreamity V3.12
                  Got openatv 7 virtual keyboard working again if text button pressed.
                  Do note openatv have fixed some of the issues I have raised.
                  Its recommend you keep updating your image as frequently as possible if trying openatv 7 image.
                  They are being a bit careless with some of their releases and obviously not fully testing the code amends or not considering 3rd party plugins when they making amends.
                  Thanks KiddaC
                  File Type: ipk enigma2-plugin-extensions-xstreamity_3.12.20210829_all.ipk (1.97 MB, https://uploadfile.pl/pokaz/2169577---zw7m.html
                  File Type: deb enigma2-plugin-extensions-xstreamity_3.12.20210829_all.deb (1.76 MB, https://uploadfile.pl/pokaz/2169578---aums.html
                  • #10
                    X-Streamity -V 3.14 Resmi S?r?m.
                    - 30/08/2021
                    nowy plik w poście Naprawiono VTi
                    poprawione zakończenia linii pliku zależności.
                    Umieść aktualizację opkg z powrotem w pliku zależności
                    VTI, Blackhole, dreambox, openatv7, python 2.7 i python 3 teraz działają.
                    enigma2-plugin-extensions-xstreamity_3.14.20210830_all.deb https://uploadfile.pl/pokaz/2170023---i3cm.html
                    enigma2-plugin-extensions-xstreamity_3.14.20210830_all.ipk https://uploadfile.pl/pokaz/2170022---hj5l.html
                    • #11
                      XStreamity 3,15
                      KiddaC napisał
                      Nowe czasowe pobieranie EPG. Teraz usunięto z ekranu transmisji na żywo.
                      Ustawienia gł?wne - ustaw dogodny dla Ciebie czas, gdy Twoje pudełko jest włączone.
                      Obrazy, kt?re nie pozwalają na wątki, nadal będą miały pewne zamrożenie funkcjonalności pudełka, gdy tak się stanie. Oglądanie telewizji na żywo będzie w porządku.
                      Więc ustaw czas pobierania, gdy nie jest to dla Ciebie niedogodnością.
                      Wszystkie inne obrazy powinny być widoczne obok braku zamrażania.
                      Menu gł?wne - Nowe ręczne pobieranie EPG - jeśli chcesz odświeżyć EPG, aby sprawdzić, czy zostało zaktualizowane. Lub jeśli nie możesz czekać na ustalony czas.
                      Pamiętaj, że teraz pobierają wszystkie listy odtwarzania EPG za jednym razem. Jeden po drugim.
                      Więc ostrzeżenie, jeśli masz wielu dostawc?w. Będzie dużo pracy w tle.
                      Dzięki KiddaC
                      Typ pliku: rar enigma2-plugin-extensions-xstreamity_3.15.20210903_all.ipk.rar (1,96 MB, https://uploadfile.pl/pokaz/2170568---3ewu.html File Type: rar enigma2-plugin-extensions-xstreamity_3.15.20210903_all.deb.rar (1.76 MB, https://uploadfile.pl/pokaz/2170572---rhfc.html
                      • #12
                        XStreamity 3.16
                        KiddaC wrote
                        ● EPG importer epg returns - for users whos providers use custom sids (satellite refs) in their data.
                        This is a secondary fallback. It checks the downloaded epg, if no epg data for that channel, then checks the epg.dat file from epgimporter.
                        Triggered same way as old. Go in live to make epg importer files. Go in epg importer select your sources and sat sources. Manual or auto download sources
                        ● https:// redirects are now followed for epg files (now takes about 1 sec - rather than 7)
                        ● Dreambox might be faster due to another tweak in our threading code
                        Thanks KiddaC
                        File Type: ipk enigma2-plugin-extensions-xstreamity_3.16.20210909_all.ipk (1.97 MB, https://uploadfile.pl/pokaz/2171301---3mcm.html
                        • #13
                          XStreamity 3.17
                          KiddaC wrote
                          ● New Vod downloader.
                          Now downloads in background. No queueing downloads for this version. Only 1 at a time.
                          Now reports size of file.
                          If IPTV stream from same provider is playing when you start the download. I stop this. Its up to you if you start it again. Then you can blame yourselves and not me.
                          ● New VOD/Catchup resume
                          This was simple to do in the end. The components were already there. I just had to learn how to use them.
                          The storage for these resumes live in /etc/enigma2/resumepoints.pkl. This probably wasn't designed for 100s of VOD files. So might be best to keep an eye on it. If it gets bloated just delete all the contents of it to refresh it.
                          Thanks KiddaC
                          File Type: ipk enigma2-plugin-extensions-xstreamity_3.17.20210914_all.ipk (1.97 MB, https://uploadfile.pl/pokaz/2171916---851d.html
                          • #14
                            XStreamity v3.18
                            Mainly getting VOD resume to work on dreamboxes. (Impossible mission - is no longer impossible)
                            Thanks seagen for your endless patience with my tweaks. (There was a lot)
                            Might still need some tweaks, i.e. deleting old resume point data to prevent file size bloat, but the foundations are there now.
                            Thx @KiddaC
                            File Type: ipk enigma2-plugin-extensions-xstreamity_3.18.20210917_all.ipk (1.97 MB,https://uploadfile.pl/pokaz/2172267---usjz.html File Type: deb enigma2-plugin-extensions-xstreamity_3.18.20210917_all.deb (1.76 MB, https://uploadfile.pl/pokaz/2172268---rlxl.html
                            • #15
                              X-Streamity - V 3.19 Official Release.
                              21/09/2021
                              Thx @KiddaC
                              File Type: ipk enigma2-plugin-extensions-xstreamity_3.19.20210921_all.ipk https://uploadfile.pl/pokaz/2172737---ed8z.html File Type: deb enigma2-plugin-extensions-xstreamity_3.19.20210921_all.deb (1.76 MB, https://uploadfile.pl/pokaz/2172738---x8gz.html
