Ipbox 900 Addons & Scripts
  • Ipbox 900 Addons & Scripts
    Multiboot for SifTeam-dgs in flash
    putting these file on your box you will be able to start when your box boots choosing the image you want
    about buttons...following Tideglo's choices(he is the enigma2 developer for sifteam images on ipbox hd ) you can:
    -pressing 1 =NFS
    -pressing 2= USB (without internal hd /dev/sda1)
    -pressing 3= USB (with internal hd /dev/sda1)
    -pressing 4=Flash
    at the next reboot you have only press the button to change images
    How install them:
    Quote:
    -rename the file for your box in usb_update.img-send and install it following the usb modality
    thx sifteam
    *Note
    the next firmware will have already it inside
    ip_welcome_pack.zip 4.14 KB http://uploaded.to/?id=s9p38l
    sigpicI did it my way
